evguy1
Sorry guys my adapters are only designed to bolt to the back of the VW TDI. Any future development is going to focus on adding more TDI adapters. This is my part time gig so time is limited until I retire.
I have the 2.2, 2.8, and V6 pattern from our EV line so it is possible. Not for a while though, need to get the new Jeep and Toyota ones built first.How about a GM 60*v6? Thats what the 4 banger s10's use.
How about using a AX15 bell housing to a AR5 transmission instead of waiting for a special adapter.How about a GM 60*v6? Thats what the 4 banger s10's use.
The four-cylinder W series are pretty strong, the W59 in my truck has over 290k miles on it, over 100k of that is with the TDI ... I have a spare transmission just in case but the stock one is still perfectAre the 4 cylinder transmissions up to performing truck duty with TDI torque pulses applied to them? Or are guys using v6 transmissions for strength?
yeah, the four cylinder truck boxes use two woodruff keys on the counter shaft input gear rather than using a spline or using a one piece cluster/counter gear ... there are way too many nissan trucks that are dead because of this flawed design… I would say if you're going to use a Nissan four-cylinder truck as a TDI conversion base then go ahead and get rid of that transmission and use a W series or R series Toyota transSince I have two nissan D21 V6 transmissions sitting around would love an adaptor for this, trans model FS5R30A. It's pretty strong and would probably handle any TDI, a variation of this model was used in the Z32 nissan 300zx twin turbo. They use the same bolt pattern but the bellhousing size is a bit larger for the 300ZX due to increased flywheel size. I believe this would be a very good option. The cost for a used 300zx is not terrible but the truck transmission can be hard to locate. The 300zx has an option for mounting the shifter further forward.
The manual transmission for the 4cyl is not so strong. People that turbocharged the factory engine have snapped the input shaft. Put the diesel torque on it and have a feeling the results would be dissapointing. The 240sx used this same transmission as the 4cyl truck. The difference is the length for the shifter location on the car is further back.
Nice to see another 22r option on the market.
Ok, good to know. I assume swapping a w series into an original v6 truck is very simple.The four-cylinder W series are pretty strong, the W59 in my truck has over 280k miles on it, over 100k of that is with the TDI ... I have a spare transmission just in case but the stock one is still perfect
