OK, finally some eye candy for those that are following with some interest. Here are pics of the current state of the project with descriptions. I hope you enjoy.
The engine block blasted/cleaned/honed/painted with #1 in place.
Crank still wrapped after polishing and balancing.
Checking piston projection after assembling bottom end. Need #3 head gasket, Frank is all over it. If you need engine parts and technical help, Frank is awsome!
This is the drivers side fixed engine mount after being tacked in place. The parts were modeled in SolidWorks and then plasma cut at a local shop. Everything fit very well.
Fixed engine mounts complete and painted. The actual mounts are for a GM 6.2/6.5 diesel. They are very effective and are much more affordable than any other option I found. Also notice the 3rd mount on passanger side of the Jeep, it is where the factory VW engine mount ties to the frame.
Weldment that ties adapter plate to engine mounts at the rear of the block. There are (4) of these. You'll see how they work when you see everything sitting in the Jeep in a few weeks.
Completed adapter plate with "ears" for engine mounts and starter hole.
Comparing stock VW flywheel to the custom TDI to AX-15 flywheel. It has a much great friction surface as well as rotating mass. I know it will make the little diesel slower to rev but should make it turbine smooth and easier to "lug" while going off-road.
VW pressure plate vs Jeep/Chrysler pressure plate. Again, a major increase in "swept" area as well as an increase in "moment" due to the large diameter. I don't think I'll have to worry about smoking the Centerforce Dual Friction Clutch no matter what kind of torque I produce in the future.
Finally, the shifter blocks for the Dana 300 transfer case. I am turning it into a twin stick so that I can run in high or low range with either front or rear drive (as well as 4X4). This makes things very nice for all weather conditions.
Thats all for now. I hope to post again in a few weeks with the engine/tranny/etc. in the frame. We'll see if that happens. Thanks for looking.
