.I'm having terrible luck getting my CP3 installed. I'm not mechanically experienced enough to do it myself, so I'm having it done.
Currently my issue is the EGR valve seems to be in the way of the metal fuel line, preventing it from connecting to the pump. Apparently you need to have an EGR delete race pipe for it to fit. I just have the EGR blocked off, but the valve is physically present. Is there any way to work around, or do I need to source a race pipe to make this work?
Whoa!! Hold on Sir. The install is quite easy and I can help you!!
First off, where do you get the kits and pump?
Either email me or post a picture of your pump and line.
Thanks!!
Andrew
tdi2micron@yahoo.ca
