87homebuilttdi
I have been searching but cannot find info that tells which pin in the 28 pin connector is for the coolant level light. I built a car that uses a 1997 AFN engine and a 1998 cluster. As I drive, the coolant level light flashes. I do not have a level sensor in the coolant bottle so therefore there is no wiring in the harness that I made. I woould like to connect the appropriate pin to ground or whatever it takes to shut off the light. Not looking to connect it to a bottle sensor. My Bentley manual does not label the pin for this.
The cluster has two connectors on the back, a white one and a maroon one. At the moment I am only using the white one.
Thank you.
Thank you.
