VCDS VAG-COM Locator
Blueyzzze
Savannah GA
2003, JETTA TDI 1.9
I now have a VCDS, located in Savannah. Still learning how to use it, so I am not a pro. But I am eager to learn.
31419
VCDS HEX-USB+CAN
Garry
passat997
Walton, ky
1997 passat
anybody close to northern Kentucky that would be willing to come scan my car and check all the things out on it? I will tip.
vegtech
New Hampshier
99 jetta tdi, 03 golf, 05 jetta pd,05 toureg all on wvo
I'm in central nh and have vag com and tools
Sent from my ADR6350 using Tapatalk 2
Wolf359
Boston
2011 Golf TDI
ISO: VCDS in the Boston, MA area, tried a couple in the area already but haven't heard back. If anyone can help out please let me know! Thank you!
2011 Golf TDI
Montezuma
Montezuma,NV/Helena MT
2005 Passat Wagon TDI,2005 Jeep Liberty CRD, 1981 Caddy diesel, 1981 dasher Diesel, 1986 quantum td, 1992 d250 Cummins, 1995 2500 Cummins, 1986 dodge d50 td.
Ross-tech hex-USB-can
Helena mt/silver peak nv 59601 89047
williamgd2
West Hartford Ct
2010 Jetta
Vag-com hex can usb West Hartford CT.
I am listed but with my old phone # PLEASE EDIT if possible. Name William Please mention the forum and there's no charge. WMGD2@att.net or text, call Cell #860-548-6379 I have been using Vag-com for a couple of years now so I am knowledgeable and would love it if you had something new that I have never done. I have programmed brand new cars right off the Lot for driver options. I enabled a new Vw alarm system the buyer didn't purchase and it was there but not activated.
Wingnut
Toronto & Whitby
Silver 2003 Jetta Wagon
It seems as though the person who started this thread has not logged on for several months. I hope everything is OK. I have sent him a message to see if he would be interested in allowing someone else to pick up where he left off and continue updating the map.
If anyone is interested in taking over, please let me know and i will try to get you set up.
kcpick
canada
03 tdi jetta, 13 tdi jetta
Vag com codes
Anyone know where a list of codes would be . I have the code, engine light on- 01164, but can't find what it it refers to.
ppopa
Dawson Creek, BC, Canada
Gorgeous Jetta PD 2004 5M
01164
Contents*[hide]*
1*01164 - ESP Operation1.1*01164 - ESP Operation: Implausible Signal1.1.1*Possible Symptoms1.1.2*Possible Causes1.1.3*Possible Solutions1.1.4*Special Notes01164 - ESP Operation01164 - ESP Operation: Implausible SignalPossible SymptomsMalfunction Indicator Light (MIL) ONPossible CausesWiring and/or Connector(s) from/to ESP Sensor Unit (G419) faultyESP Sensor Unit (G419) faultyWiring and/or Connector(s) from/to Steering Angle Sensor (G85) faultyPossible SolutionsCheck Wiring and/or Connector(s) from/to ESP Sensor Unit (G419)Check/Replace ESP Sensor Unit (G419)Check Wiring and/or Connector(s) from/to Steering Angle Sensor (G85)Check/Replace Steering Angle Sensor (G85)Special NotesThis Fault Code is being stored after about 5 Seconds of continues ESP activity.
ou have posted on a wrong topic.
But....
kcpick
canada
vag-com
I cleared the code yesterday without any issue. The engine light back on today. This a 2013 tdi. Is the ESP sensor that common of a problem. I have always had older jettas until now. I assume I will have to clear this constantly.
