ricardotdi
For Sale:
2006.5 Jetta TDI "Special Edition"...
Build date 11/06
now has 190,000 miles on it
1.9L BRM
Reflex Silver exterior
Black interior
DSG
Moonroof
Heated Seats and Mirrors
CD Player
XM Radio
Rear Spoiler
A/C
Cruise control
Maintenance done in past 12 months…
New EGR, intake cleaned out of carbon crud build up.
New timing belt, water pump, relay and idler, thermostat and housing, serp belt & DSG service,...(all done at 183,000 miles).
The cam is original, and my guru reports after inspection that only two of the lobes are showing "medium" signs of rounding off. He said that they were within the wear parameters for that many miles. I have seen/felt no symptoms of any cam problems at all.
Past misc. service: Dual mass flywheel replaced at 140,000 miles, 1 CV boot replaced due to tear (CV not allowed to dry out of grease), cam timing sensor replaced, transmission case external oil leak sealed up and fixed. Lower right front control arm replaced. That's it.
The Good...
AC works great
Heated seats work great
4 tires with lots of tread left...General Altamax HP installed at 166,000 miles, new rear rotors and pads at 166,000 miles
I had Bilstein HD struts and shocks installed at 116,000 miles and replaced strut mounts at that time. No creaking suspension anymore...and talk about great handling on and off the highway ramps!
Car runs fantastic and shifts smoothly. Passed recent NJ m.v. inspection.
The Bad..
two small dents in passenger side rear door near lower edge, paint not broken (I touched them up with reflex silver paint)...
Rocker panel passenger side has two minor dents
I have to add maybe 1/3-1/2 of liter of oil in between change intervals.
Both headlight lenses are starting to glaze over along top edge.
That's it.
Car drives and runs 100%. 75-80 mph no problem if your license & insurance can handle it. alignment is true...no drifting or pulling.
I am the 1st and only owner since new. Always garaged. After 8+ years I still average 45mpg. The only reason I'm selling it is I purchased another car. It will sadden me to say good bye to this very reliable, cost effective car that has served me so well.
I will be consoled if a worthy TDI buyer takes it over from me.
I certify that no VW dealer has ever worked on this car!!!...that's right...I am the only one who has ever changed the oil since the first 5,000 mile change interval. I have all service and repair records of course... I started the 1st 40,000 miles with Castrol 505.01 5W-30, then switched over to Pentosin 5W40 and used it ever since. Of course I changed it every 10,000 miles, and did the complete 20K service when needed.
All major work and maintenance has been done by a great diesel mechanic in Shrewsbury, NJ--he is a trained Porsche-Audi VW TDI tech.
Clean title in hand. Car located in central N J.
Best way to contact me, Richard, is via text 908-902-9891
$6,000 obo. Cash or cashier's check from recognized bank only. If you are seriously interested I will text you photos.
Build date 11/06
1.9L BRM
Black interior
DSG
Moonroof
CD Player
XM Radio
Rear Spoiler
A/C
Cruise control
The Good...
AC works great
The Bad..
That's it.
