So I too am about to begin a euro conversion. My question for someone out there is,
does the entire exhaust system need to replaced or do I just remove the catalytic converter?
Also, can I use the existing 5 speed tranny from the gasser? One person mentioned needing a different 5th gear for the diesel.
I'll post some pics once I start this project.
Thanks!
the diesel's seem to have the same (except for the diesel 'cat) downpipe with the 'flexi' or inverted bell connection onto the manifold / turbo outlet, if your van is petrol then it will probably need a diferent downpipe?
as to the 'cat', if you can escape emission rules then bin it
Gearbox info might help work out ratio diferences? (stolen from another forum
The 02B Gearbox is a beefed up 5-speed gearbox derived from the new cable operated 02A gearbox first found in the '89 Corrado, '88 Passat and Mk2 Golf G60 and grew into the 02Z gearbox found in the 4-cylinder T5 models.
Gear selection in the Transporter is relayed by heavy duty rods rather than cables and the final drive casings are enlarged to house a bigger - and stronger - crown wheel and pinion.
The Transporter clutch is either actuated hydraulically by an externally mounted slave cylinder (on all rhd vehicles, all vehicles with additional heater and all vehicles destined for Canada) or mechanically by a self adjusting cable.
Gearbox Code Type Oil Capacity (Litres) Final Drive 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear Reverse Gear Speedo Year
AFK 02G 2,3 82:21=3,905 43:11=3,909 36:17=2,118 35:26=1,346 35:36=0,972 35:48=0,729 37:23x23:10=3,700 13:22=0,591 08/9507/99
AFL 02G 2,3 82:21=3,905 43:11=3,909 36:17=2,118 35:26=1,346 35:36=0,972 35:48=0,729 37:23x23:10=3,700 13:22=0,591 08/9507/99
AYD 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 40:28=1,429 35:34=1,029 36:43=0,837 19:9x36:20=3,800 12:20=0,600 06/9008/91
AYE 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 39:29=1,345 34:35=0,971 34:45=0,756 19:9x36:20=3,800 12:20=0,600 06/9008/91
AYF 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 39:29=1,345 34:35=0,971 34:45=0,756 19:9x36:20=3,800 12:20=0,600 06/9008/91
AYG 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 40:28=1,429 35:34=1,029 36:43=0,837 19:9x36:20=3,800 12:20=0,600 08/9108/92
CCW 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 08/9108/92
CCX 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 08/9108/92
CCY 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 08/9108/92
CCZ 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 08/9108/92
CHP 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 08/9208/93
CHR 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 09/9208/93
CHS 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 09/9208/93
CHT 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 09/9208/93
CPV 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 31:23=1,348 29:30=0,967 30:39=0,769 18:9x36:20=3,600 12:20=0,600 01/942/95
CPW 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 31:23=1,348 30:29=1,034 31:37=0,838 18:9x36:20=3,600 12:20=0,600 01/9412/95
CRL 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 09/9312/95
CRM 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 09/9312/95
CRN 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 09/9312/95
CRP 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 09/9312/95
DCU 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 32:22=1,455 30:29=1,034 31:37=0,838 18:9x36:20=3,600 12:20=0,600 01/9605/97
DCV 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 4:45=0,756 18:9x36:20=3,600 12:20=0,600 01/9605/97
DCW 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 31:23=1,348 29:30=0,967 30:39=0,769 18:9x36:20=3,600 12:20=0,600 01/9605/97
DCX 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 01/9605/97
DJZ 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 4:45=0,756 18:9x36:20=3,600 12:20=0,600 01/9605/97
DKA 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 01/9605/97
DQG 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 32:22=1,455 30:29=1,034 31:37=0,838 18:9x36:20=3,600 12:20=0,600 06/9709/00
DQH 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 31:23=1,348 29:30=0,967 29:39=0,744 18:9x36:20=3,600 12:20=0,600 06/9709/00
DQJ 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,97 34:45=0,756 18:9x36:20=3,600 12:20=0,600 06/9709/00
DQK 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 06/9709/00
DQL 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 06/9709/00
DQM 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 06/9709/00
DQR 02B 2,3 71:18=3,944 43:11=3,909 36:17=2,118 35:27=1,296 34:38=0,895 34:49=0,694 37:23x23:10=3,700 elektr. 07/9906/03
DRH 02G 2,7 74:15=4,933 43:10=4,300 37:16=2,313 35:26=1,346 33:38=0,868 32:51=0,627 37:23x23:10=3,700 elektr. 07/9906/03
DUH 02B 2,5 72:17=4,235 34:9=3,778 33:16=2,063 31:23=1,348 29:30=0,967 29:39=0,744 18:9x36:20=3,600 12:20=0,600 06/9809/00
DUJ 02B 2,5 72:17=4,235 34:9=3,778 36:17=2,118 30:23=1,304 28:31=0,903 28:40=0,700 18:9x36:20=3,600 12:20=0,600 06/9809/00
DXZ 02G 2,3 82:21=3,905 43:11=3,909 36:17=2,118 35:26=1,346 35:36=0,972 35:48=0,729 37:23x23:10=3,700 13:22=0,591 07/9906/03
DYA 02G 2,3 82:21=3,905 43:11=3,909 36:17=2,118 35:26=1,346 35:36=0,972 35:48=0,729 37:23x23:10=3,700 13:22=0,591 07/9906/03
EEZ 02G 2,3 71:18=3,944 43:11=3,909 36:17=2,118 35:27=1,296 34:38=0,895 34:49=0,694 37:23x23:10=3,700 elektr. 05/9807/99
EFA 02G 2,7 74:15=4,933 43:10=4,300 37:16=2,313 35:26=1,346 33:38=0,868 32:51=0,627 37:23x23:10=3,700 elektr. 03/9807/99
EVU 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 32:22=1,455 30:29=1,034 31:37=0,838 18:9x36:20=3,600 12:20=0,600 09/0006/03
EVV 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 09/0006/03
EVW 02B 2,5 73:16=4,563 34:9=3,778 33:16=2,063 31:23=1,348 29:30=0,967 29:39=0,744 18:9x36:20=3,600 12:20=0,600 09/0006/03
EVX 02B 2,5 84:17=4,941 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 09/0006/03
EVY 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 34:25=1,360 34:35=0,971 34:45=0,756 18:9x36:20=3,600 12:20=0,600 09/0006/03
EVZ 02B 2,5 83:18=4,611 34:9=3,778 36:17=2,118 35:24=1,458 35:34=1,029 36:43=0,837 18:9x36:20=3,600 12:20=0,600 09/0006/03
EWA 02B 2,5 72:17=4,235 34:9=3,778 33:16=2,063 31:23=1,348 29:30=0,967 29:39=0,744 18:9x36:20=3,600 12:20=0,600 09/0006/03
EWB 02B 2,5 72:17=4,235 34:9=3,778 33:16=2,063 30:23=1,304 28:31=0,903 28:40=0,700 18:9x36:20=3,600 12:20=0,600 09/0006/03
FJS 02G 2,3 82:21=3,905 43:11=3,909 36:17=2,118 35:26=1,346 35:36=0,972 35:48=0,729 37:23x23:10=3,700 13:22=0,591 03/0106/03
FTV 02G 2,3 74:15=4,933 43:10=4,300 37:16=2,313 35:26=1,346 33:38=0,868 32:51=0,62 37:23x23:10=3,700 13:22=0,591 04/0106/03
sorry for the blatant sledge-hammer of useless info
Rich.
