arne487
My CQ has a throttle pot controlled by the throttle cable. It's right on the throttle body. It's been working fine for 24 years, so I don't see why it wouldn't work in your application.
yes, thats what I am saying. It would be mounted to maybe the firewall somewhere. Just making sure the enclosure would be ok with underhood temps/possibility of moisture. It looks pretty well sealed.Are you saying use the throttle cable to actuate the pot??? I guess that would work. The mk4 dbw pedal takes up a lot less space and you could easily adapt it to bolt up to the audi firewall Im sure.
i will look for one of those. I have a pretty tight budget on this build (my woman moved out and now im paying the whole mortgage alone), so certain expensive euro bits might have to be sacrificed for less than ideal setups. Ah life, sometimes you are a cruel *****.Use a pedal assembly from a Euro B4 tdi...
Use a pan, pickup and oil filter/cooler from AEB 1.8tthis test has revealed that i have an oil pan interference with the subframe and an oil filter collision with the factory chassis side engine mounts. The solution appears to be an oil pan from any longitudinal vw or audi with a 4 cylinder and the oil filter solution appears to be a mount/cooler from a longitudinal 1.8t.
Thanks man! Hopefully you will see it around this coming winter. Yes, that stove in the insulated shop makes it great to work in the winter. I can work in a t-shirt after the stove has been burning and hour.glad to see your still working on it! Looking good
Love the Vermont castings defiant in the background... must be warm in the winter
