Conorooney
Hi all,
Complete car noob here. I've been searching the forums for an answer and while I think I've narrowed it down I'm still without a definitive answer. Luckily the brother in law has VCDS and we should be able to narrow it down a little more but he won't be here until next week.
I bought a 2011 B7 Estate last week. Love it since I can fit every including the kitchen sink in the bag which is great what feel like moving house when packing for the baby.
The air con is blowing warm air (it was 30 degrees today in Ireland ) but there is refrigerant in the system. The air con does light up and I can hear a change when I go to the cold setting. I checked all the side fuses for continuity and the fuse board on the engine (except the 370 relay but I think that's for the ECU so if it was gone the car wouldn't start. I know there are air con relays somewhere under the dash but I don't know where to look or how to access. I've also noticed that when I turn on the air con the two cooling fans at the radiator don't turn at all so I'm going to guess this has something to do with it. I'm not going to leave it in to get checked out until I get it plugged into VCDS. I haven't taken it on long journeys yet so don't know if they come on when the engine reaches a certain temperature.
Any suggestions? Baked in the car. Cheers for any help folks.
https://ibb.co/hofBzy
https://ibb.co/mZw6XJ
https://ibb.co/fBD9md
https://ibb.co/iKdWzy
