Danielliam
I am having a helluva time with this car and any help would be greatly appreciated. I have been getting limp mode which was previously intermittent and now is persistent and constant. If I clear the codes with the basic trouble computer they come back within 3 seconds of starting the car up. I have not used VCDS yet but have a friend with it who will scan the car next month when he is home if I cant solve the problem before then. I have replaced the CHRA (took turbo apart to clean VNT and saw the fins looked like something had gone through them and chewed them up a bit), the vnt actuator (Kermatdi replacement), n75, boost sensor, vacuum lines, and disassembled and cleaned the egr, cooler, and intake parts.
-The boost sensor is a bosch sensor from Napa
-The N75 I bought was this one: http://www.ebay.com/itm/FOR-VW-TDI-...-Jetta-Passat-Golf-Beetle-00-06-/281840365293
-The CHRA was from Alamo Turbo in Washington. They are legit, not a cheapo knockoff
-as I said Kermatdi VNT actuator
I am getting the emissions workshop message, P0245 "wastegate solenoid low a", P2102 "throttle actuator control motor circuit low", P2100 "throttle actuator control motor circuit/open", and P0299 "Turbocharger underboost"
I am a poor grad student and have blow all of my expendable income trying to have a working car. Please help if you can, I can't afford to throw many more parts at this car
