peiphil
- Joined
- Nov 7, 2012
- Location
- Tignish PEI Canada
- TDI
- 2005 passat GLS TDI and big old Dodge Cummins TDI
That is just your your opinion and is not a fact.no surprise rock auto doen't have access to that piston. It is a item that normally rock auto would buy from a dealer who discounts but they would lose money filling your order. if you were to do as Peiphil suggests, using used piston and used rings, and not putting a nice 30 degree crosshatch using a 240 grit hone, you'll have a smoker, as the cyl glaze will prevent seating for the used rrings or new ones for that matter. I feel certain Jason knows better than to attempt that. As I said, rock auto would not even be a consideration for me to find parts. Did you try J.C.Whitney? They are about as useless.
Unlike a gas engine his block most likely still shows the original cross hatch hone marks
