TigerDriver
$3500
Car
183xxx miles, I did the timing belt @ 127000 (IDparts kit). Always serviced on time with LiquiMoly (IDparts kits).
The good; last year of the ALH, runs excellently and get's 40-42ish mpg with my lead-foot fiancee's mostly around town driving. Transmission/clutch good. Everything works. Starts easy in the winter (has an oil pan heater but didn't need it after replacing the battery with the correct one).
We bought the car with 126k, it had a grease car kit which I promptly disabled, it still has the tank in the spare tire area, switches and gauge, solenoids. I don't believe it was driven on grease too much and it has shown zero oil consumption between 10k changes.
Comes with 2 extra wheels with studs, brand new carpets & weather mats & trunk liner.
The bad; Warped or glazed rotor causes some shaking but braking action is still very good. The brake pad warning light is due to a broken wire on the pad itself; replacing pads will fix it. Minor rust at front wheel wells and on driver door pillar. Dent on left rear wheel arch and passenger door. Minor dent on rear lift gate. Front bumper is a bit crooked and one head light was replaced. Duct-tape residue on rear window from temporary license plate. Medical tape on cluster as the brights indicator was too bright.
Service Record:
odometer service_date sub_service_types
182779 6/18/17 air_filter,engine_oil
175900 12/29/16 battery
172436 7/26/16 engine_oil
171693 6/24/16 brakes_rear,Calipers, Rear Calipers from napa, lifetime warrety
166200 12/24/15 Wheel bearing left front,Brake master cylinder
162757 9/26/15 engine_oil
151621 1/8/15 engine_oil
147250 10/24/14 Front Struts,Front shock mounts,Front and rear shocks,Sway bar mount
143140 8/11/14 engine_oil
142664 8/2/14 a/c_filter,air_filter
142000 7/18/14 Other Sway bar link ends (front)
141400 7/4/14 Mass airflow sensor
0 6/9/14 Other Replaced intermediate exhaust pipe. Major muffler.
136280 4/18/14 Emergency brake line replacement,Thermostat,Wheel bearing. Right front. German auto repair guaranteed two years
134518 3/18/14 engine_oil
129421 12/6/13 tire_b,tire_a,tire_d,tire_c New wheels and tires.
127200 11/5/13 brakes_front,windshield_wipers,registration,transm ission_fluid,air_filter,fuel_filter,timing_belt,br akes_rear,engine_oil, turbo actuator
Car
Service Record:
