theedudenator
Check engine light and glow plug flashing.
Car drives and acts like normal.
Used my Ross-Tech VCDS to see what the code is.
DTC P2563 Turbocharger Boost Control Position Sensor Performance
This code means the sensor has high resistance or signal performance.
I checked the sensor wiring, nothing is broken and the plug is not corroded.
Took the dealer, they are saying the turbocharger is bad and want $3,500 to replace it.
Does this sound normal?
Anyone changed one of these before? Does the engine get pulled?
