GoFaster
Moderator at Large
For the last month before the car goes back:
1. No slowing down for speed bumps.
2. Drive on gravel roads whenever possible and as fast as possible.
3. The only allowable accelerator positions are 0 and 1. Light switch.
4. All starts from a stop shall be done by mashing the accelerator all the way to the floor (engine at redline) then side-stepping the clutch.
5. All corners are to be taken by cranking the steering wheel to full lock and as fast as you dare.
6. Only use the hand-brake for coming to a stop ... no using the foot brake except in an emergency.
7. Field car? No problem.
8. Kids throwing up in the back seat? The more the merrier.
9. Eating fast food inside? Sure. Smoking? If you're into that sort of thing. Maybe even wacky-tabacky.
10. Last but not least, strip out everything not yet broken that is not necessary for the car to function under its own power.
If it's going to the junk pile, it's going there as worthless as possible. No parts left on it that are worth the time and effort to remove. No tread depth left on the tires. Nothing left on the brake pads. It will stink and it will look like armageddon struck.
