RedBaron134
Ok here is the situation, I bought this jetta for my step son from a buddy who had the timing belt break on him. Minor damage to the head. The car sat for almost a year and a half and here is where we are at. The head has been replaced with a re-manufactured. Complete with new camshaft. We replaced the water pump, all the tensioners, and pulleys on the front. all the gaskets for the top end as well were replaced. I have bled the fuel system, and replaced relay 109. I can not get this thing to start for the life of me. I have included the vag-com results at the bottom of the post. Any help would be appreciated. I am a skilled mechanic but this one has me stumped. The results show the Fuel Shutoff solenoid open or short to ground, I have that bypassed at the moment to verify fuel flow which I have.(it was an initial problem). We also replaced the battery after the car sat dead for a good portion of a year. I also used fresh fuel to make sure there isn't an issue with water or gelling.
VIN: 3VWRF29M1YM004569 License Plate:
Mileage: 390710km-242775mi Repair Order: 00001
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Mileage: 390710km/242775miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 BD
Component: 1,9l R4 EDC G000SG 2507
Coding: 00002
Shop #: WSC 00066
VCID: 53A599C7A1009386791-4A3A
1 Fault Found:
17946 - Fuel Shutoff Solenoid (N109)
P1538 - 35-00 - Open or Short to Ground
Readiness: 0 0 1 0 1
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066
VCID: 3E73D8733A826EEEA6F-49D8
No fault code found.
Part No: 6Q0 909 605 A
Component: Z9 AIRBAG VW5 0003
Coding: 23097
Shop #: WSC 00066
VCID: 3561C75F0FB4ADB6775-49D8
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 L
Component: A4-KOMBIINSTR. VDO V54
Coding: 07242
Shop #: WSC 00066
VCID: 2B55E127D9F0EB46111-5072
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0X1303630
IMMO-IDENTNR: VWZ7Z0X1303630
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: F0EFB64BB056489EE43-5072
1 Fault Found:
Address 35: Centr. Locks Labels: 1C0-962-258-II.lbl
Part No: 1C0 962 258 P
Component: 0J Zentr.Verriegel. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 3467FA5B04CEB4BE40B-4A9C
2 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
00953 - Interior Light Time limit
End ---------------------------------------------------------------------
75 76
Coding: 00002
Shop #: WSC 00066
1 Fault Found:
Coding: 03504
Shop #: WSC 00066
Coding: 23097
Shop #: WSC 00066
2 Faults Found:
Coding: 07242
Shop #: WSC 00066
1 Fault Found:
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
Coding: 04096
Shop #: WSC 00066
2 Faults Found:
