Old June 15th, 2018, 07:01   #16
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Originally Posted by TDIfarmer View Post
That was my next step to look at fuel pickup.But how come I pulled fuel through filter and then had good pressure from Ip when I loosened the injector lines.And it still did not fire?
Connect a long clear hose to the IP return line. Suck on the hose until you get solid fuel. Reconnect, crack an injector or 4, rags, crank briefly, should spray.
Old July 2nd, 2018, 16:28   #17
TDIfarmer
TDI(s): 99 GL
Default Fixed it yesterday
I am very proud it is running again.I pulled the fuel pickup/sending unit out and it had a bunch of slimmy alge and mud looking crap inside the pickup.I cleaned the pickup and pumped tank out.Cleaned the bottom of the tank.Got air out of fuel system and then it fired up and runs great.
TDIfarmer is offline   Reply With Quote
Old July 2nd, 2018, 21:10   #18
whitedog
Casey nailed in the second post.
Now it's time for some anti-algae additive.
Can rent movies at BlockBuster.
whitedog is offline   Reply With Quote
2002 Jetta No start, No turnover any Ideas? smoan VW MKIV-A4 TDIs (VE and PD) 5 December 8th, 2015 20:48
2000 Jetta No Start RedBaron134 VW MKIV-A4 TDIs (VE and PD) 13 November 20th, 2015 20:22
2000 jetta no start but cranks fine. Any protocol for the no start? Speardog VW MKIV-A4 TDIs (VE and PD) 3 January 23rd, 2015 13:44
'01 Jetta will not start hot, ideas? five7driver VW MKIV-A4 TDIs (VE and PD) 1 August 27th, 2012 13:34
'02 Jetta won't start--any ideas? JMarg TDI 101 22 January 5th, 2008 08:04
Page generated in 0.11929 seconds with 12 queries
[Output: 59.20 Kb. compressed to 53.83 Kb. by saving 5.36 Kb. (9.06%)]
