Mike_04GolfTDI
- Joined
- Nov 19, 2003
- Location
- Richmond, BC, Canada
- TDI
- Mine: 2019 Golf R DSG, Wife's: 2015 Golf Comfortline TDI
Edit: It turned out the problem with this car was a faulty ignition switch. Most of the thread is just speculation about what the problem might be, so may or may not be accurate for other cars with similar symptoms. (In other words, the stuff about the controller coding might not be correct. It's just speculation.)
This 2015 Mk7 Golf TDI had a new headlight installed, and now it has this fault code. The status display in the car shows "Vehicle Lighting Fault" with the headlights highlighted in orange.
The original driver's side headlight was damaged in a very minor accident a month ago. It just had a crack in the plastic, but still worked. The car was driven for a month with the headlight like this. There were no fault codes with the cracked headlight.
Today the headlight was replaced, and everything works (high-beam, low-beam, signals, marker lights, etc) AND the headlight switch in the car works properly too. I REFUSE to believe that the switch actually became defective coincidentally on this day.
Is there any way replacing a headlight could cause a switch fault code?
I've cleared the code several times and it immediately returns.
The lights are just regular halogens. Not HID lights. There's nothing fancy about them. Please tell me they don't have a supercomputer hidden in the headlight module or something.
Address 09: Cent. Elect. Labels: 5Q0-937-08X-HV1.clb
Control Module Part Number: 5Q0 937 087 N HW: 5Q0 937 087 N
Component and/or Version: BCM PQ37BOSCH 028 0106
Software Coding: 00101946404182E949E44000091407001000000000000000000000000000
Work Shop Code: WSC 00066 790 00208
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004 (VW37)
ROD: EV_BCMBOSCH_013.rod
VCID: C689483779EE4B7670-8092
1 Fault Found:
919560 - Light Switch
B126A 29 [136] - Signal Implausible
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 48614 km
Date: 2017.11.15
Time: 18:27:44
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 48614 km
Date: 2017.11.15
Time: 18:27:44
