Old December 13th, 2018, 17:49   #1
nick_martin0428
Default Please give me your opinion on this camshaft
This is a new billet camshaft from ID Parts. The chamfer size on the lobes seem to be different for one side than it is on the other. I tried to take good pictures to show what I'm seeing. All of the lobes are like this. Would this be a problem? I've replaced the camshaft once before, and I don't remember this on the previous one. Thanks for any input you have.
https://imgur.com/EMh6Zu1
https://imgur.com/utSM2sQ
https://imgur.com/VASAF0W
nick_martin0428 is offline   Reply With Quote
Old December 13th, 2018, 17:57   #2
kdawg89
Iíd use it.
15 Golf TDI SEL DSG, Kerma TDI Tunes
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old December 14th, 2018, 19:28   #3
nick_martin0428
Thanks for your reply. I guess I'll put it in since no one else has anything to say, and I need to before winter. I hope the slightly different pressure and position on the lifter faces doesn't destroy anything.
Old December 15th, 2018, 08:06   #4
JETaah
Well, it is what it is...aftermarket...a copy of the original lobe design profile and all its shortcomings plus a couple more.
The excessive chamfer is arguably unnecessary and only narrows the camshaft lobe more yet. Makes me think that the manufacturer did not know the importance of that or that it was somehow easier for them in production to do so. Perhaps it allows the cam lobe tips to wear more and still have a chamfer...don't know. The original OEM cams as well as the upgraded aftermarket versions have a very minimal chamfer. Seems to me that ANY consistent chamfer is good enough and the smaller the better if the metallurgy is robust enough.
If you do not plan on putting heavy duty commuter miles on the car before selling it, it may be just fine.
Old December 15th, 2018, 16:22   #5
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
I trust you are replacing all the lifters as well.
sptsailing is offline   Reply With Quote
Old December 15th, 2018, 16:25   #6
kdawg89
Good point! OP, definitely make sure to replace the lifters! I also strongly recommend using a PTFE cam seal, not a spring seal. A spring seal eventually wore a groove in my billet cam and started leaking. Make sure to follow PTFE seal install procedures to ensure it doesnít leak. Makes the job take longer because it has to sit undisturbed but itís worth it.
Old December 16th, 2018, 00:39   #7
nick_martin0428
yes, I am replacing all lifters and tty bolts
Old December 16th, 2018, 00:41   #8
nick_martin0428
I haven't heard that about the seal. I will look into the one that came with the kit.
Old December 16th, 2018, 08:43   #9
kdawg89
Itís really easy to tell, if there is a spring keeping pressure on the sealing surface, I wouldnít use it. If there is no spring itís PTFE and I would use it.
Old December 16th, 2018, 17:53   #10
sptsailing
sptsailing's Avatar
Franko6 sells great camshafts, that in my opinion and apparently the opinions of others as well, are better than stock replacements. Please consider reviewing threads containing information on his cams, camshaft bearings and alternatives to single use camshaft bolts, all of which he sells. Even if you use a standard cam, you may wish to consider at least using his modified cam bearings and alternate cam bolts.
Old December 16th, 2018, 18:34   #11
03TDICommuter
Franko6 sells great camshafts, that in my opinion and apparently the opinions of others as well, are better than stock replacements. .
Does Frank06 have an online storefront? I'd like to see what he offers in preparation for a future repair.
2003 Jetta TDI, 5 spd, 353K miles, original engine/turbo
- 319,300 miles - turbo vanes cleaned, replaced control ring
03TDICommuter is offline   Reply With Quote
Old December 17th, 2018, 18:44   #12
mnbrown25
No, Frank06 does not have an online store. You will need to call him and speak to him. He is very easy to talk to and will provide you a ton of information.
mnbrown25 is offline   Reply With Quote
Old December 29th, 2018, 09:47   #13
pedroYUL
pedroYUL's Avatar
Fuel Economy: ~17.5 km/L
I believe the chamfer is there just as a quick visual check on part degradation
pedroYUL is offline   Reply With Quote
Need a second opinion: Is it really time to give up and get a new car? Forbes77 TDI 101 16 May 11th, 2015 15:19
WTB: Looking at buying this car give me your opinion christonian Ontario 70 August 21st, 2012 10:13
Give me your opinion windscreen replace JayT TDI 101 21 March 23rd, 2009 18:49
Want to give an opinion on what my VW is worth? cody TDI Cars for Sale/Wanted 2 June 27th, 2003 08:28
look at this pic and give me your opinion VWMike81 VW MKIV-A4 TDIs (VE and PD) 21 January 4th, 2001 01:32
Page generated in 0.17180 seconds with 12 queries
[Output: 113.19 Kb. compressed to 94.93 Kb. by saving 18.26 Kb. (16.13%)]
