MaroonB4
I am a glutton for punishment...so when I found a 96 (perfect match to my 97!)with 149k on it for CHEEEEEEP, I had to do it! The problem I have right now is that the engine will not shut off when i turn the key off, but if i turn it back on/off quick then the engine shuts off. I do have a lit CEL, but the OBDII scanner will not communicate with the vehicle. Will a VAGCOM read the CEL when and OBDII cant?
I replaced the ignition switch and the vaccuum line inside and outside the ecu today and still have the same problem. My glow plug light also flashes intermittently and the engine idles a little high (1100-1200 rpm). I also have an intermittent bubbling of air coming from the fuel filter into the line between the filter and the pump.
The car is also a little light power, but I can hear the turbo spooling. (maybe N75?)
I know there are a myriad of issues/possible fixes for these issues....where do I start?
Thanks!
Thanks!
