My VAG COM readings straight from the pump read around 185 deg in the summer time. You can't really ask for anything better than that. Also, my oil is ready to be injected when my car is up to operating temperature. Again, you cant ask for anything better than that.
GC FPHE kit is hugely overpriced and a huge rip off. But, a FPHE is the way to go.
As far as burning better, after 180 deg the viscosity in relation to temperature graph starts to level off really fast. Anything higher than 190 reallly nets you very little in the viscosity department; however, the risk of damaging parts in your IP really start to rise quickly.
Science studies have shown canola oil to exhibit similar viscosity measurements of diesel fuel at or around 302 deg F. This is impossible to achieve safely pre IP, and I have not found a way of doing this post IP. I thought injection line heaters was the key but they do absolutely nothing. The oil does not sit in the injection lines long enough for sufficient heat transfer (noted by very little to no temperature changes from my temp sendor on my return line) This was found at highway speeds. Stop and go or city traffic may be a different scenario but I do not like to burn VO in that situation for a very long time.
As far as better atomization goes, 180 deg oil temps will be fine. If your so concerned, you can have your popping pressures of your nozzels increased to help atomize the thicker fuel better. My experience has shown it to run just as good if not better on VO therefore, its burning very similar to diesel, at least in making power.
