carsaremytoys
I'm doing a large mechanical overhaul. After replacing the control arms, ball joints, and sway bar end links I took the car for a spin. Yes my alignment is off, but what I'm concerned about is the brake pedal going to the floor. After a few miles the pedal did firm up, but still not where I know it should be. I have all new rotors and pads that I matched up to my current. The rotors look the same, the pads do look to be a bit work on the rear, fronts look good. Before I change the rubber lines and flush all my expensive ravenol brake fluid through... I wonder if I have a master cylinder issue?
To recap, I had to front wheels off to do control arms, ball joints, and sway bar end links. Test drive was questionable, allowing the brake pedal to go to the floor. After a few miles the pedal stiffened up a bit, but not to where it should be. Master cylinder issue?
