What is up with this? Any ideas other than bad Trans. Reverse works fine. Fluid level good. I pulled pan. No chunks. Getting ready to pull filter and check solenoids. Ant good procedure for doing solenoid test?
Deming. If you decide to sell the auto I will probably be in the market. Dropped pan and found non ferris metal chunks and a bunch of shavings in filter. I don't know wether to scrap this thing or put a trans in it. I have only had 3 months. Can't afford a 5 speed swap.
