I just bought a used 2012 Passat TDI SEL and its a great car. Unfortunately the previous owner was a heavy smoker. I've gotten most of the smell out and replaced the cabin filter (it was gross) but the AC still blows a stinky. On a recommendation from a friend I bought a can of spray designed clean the AC. It's called Kool-IT and it's designed with a hose to insert in the AC drain under the car. Apparently you empty the contents into the AC via the drain and then let it run out. Unfortunately, I can't find the hose. In fact, after running the car with the AC on during my 45 minute commute, I see NO water dripping under my car. I've read threads where the water is actually leaking into the car, but that's not the case for me - I hope. I've searched around and found similar posts for older Passats but none for mine.
Anyone out there know where to find this hose/port? Also, if there's no water dripping under my car should I be concerned?
Thanks in advance for your help.
