evolDiesel
I was hoping to get some ideas from the veterans on what could possibly be causing the following:
INFO
CAR: 2011 JSW TDI DSG
MILES: 45,000
PROBLEM
I'm getting a vibration, almost a shuddering up around 75mph. It is more pronounced under load, i.e. flooring the go-pedal up a hill. It's pretty bad but starts to let up around 90mph. Unfortunately I don't know if it's a particular RPM - but I only notice under load (6th gear). My tires are not great, and the rear tires are downright awful but not sure why it would be the tires if it gets worse with load. I should add that I just had all 4 tires ballanced and an allignment done.
The only times I've felt something similar to this was in a V10 Touareg TDI and the Liberty CRD. In both cases it ended up being the fuel filters (in the Touareg it was 2 filters.. because it has one for each 6-cylinder bank ). But those were shuddering and a definite lack of power. I don't think I have a lack of power.
OK... any thoughts or experiences? Other things I should be looking for? THANKS!
PS - I'm due for my service and I will be changing the fuel filter; this weekend or the next one.
INFO
MILES: 45,000
PROBLEM
