BarryB
And... CEL is on again, and AVG MPG dropped AGAIN.
AyeTry member DerekG........he has all that for sale
Running b100 on a common rail isn't recommend...A tune and the gutting of this emissions crap should get you passed pretty much any emissions check.....
These engines, the CR engines are cleaner with all of this stuff removed and the engine ecu flashed than a car with a fully emission's 1Z/ALH engine from 96-03. If cleanliness is part of the reason you purchased one of these comparing this setup like I describe I would not give a second thought to getting rid of that crap!
And with a tune to remove all those wasteful after stroke injections it can run on high %'s of BD, maybe even B100 if you wish.
And if you drive it right afterwords you should see from 5-15 mpgs better than before getting well above the 50 to even 60 mpgUS mark tank after tank.....
FYI, Barry and I reached an agreement over a week ago for the purchase of my parts. I'm removing my DPF and ERG's tomorrow and everything will be in a box ready to ship.Aye
All the parts are off the car and in a box already.
While there are other issues for sure in running high %'s of BD in a CR, in any diesel engine the real show stopper so far has been the after stroke fueling to make the current emissions crap function which has proved to dilute engine oils. Diluted engine oils means shorter service lives of that oil, which increases costs of operation........Running b100 on a common rail isn't recommend...
Good read on the subject:
http://forums.tdiclub.com/showthread.php?t=284919
Awesome! You're going to love the car.FYI, Barry and I reached an agreement over a week ago for the purchase of my parts. I'm removing my DPF and ERG's tomorrow and everything will be in a box ready to ship.
I'm installing my midpipe/downpipe and race pipe this weekend and my ECU gets a reflash on Friday. I'm really looking forward to the update.
mid 50's mpg without even trying that hardSOOOOOO with I could delete and tune my stuff. Love to get the extra MPG.
I agree with you on most points. The main issue that's been discussed is deposits in the injectors caused by first gen biodiesel in high concentrations. These deposits over time will eventually clog the injectors. I'm pretty sure that was a CR diesel that I saw cutaways of after biodiesel was used for a extended period.While there are other issues for sure in running high %'s of BD in a CR, in any diesel engine the real show stopper so far has been the after stroke fueling to make the current emissions crap function which has proved to dilute engine oils. Diluted engine oils means shorter service lives of that oil, which increases costs of operation........
Remove that stuff you can program out the after stroke fueling removing that issue from the equation......
You need your ECU tuned to delete the DPF.So what does the DPF delete run without the Malone software? I have Malone and I can vouch for Sal. Great guy.
My guess is probably , yes. Wouldn't bank on it though. If you do have a sniff test, make sure the car is good and warmed up first. The emissions are way lower once warmed up.Well, my replacement parts are on order. Much thanks to Perry01 for a smoooooth transaction. Question, with a tune and DPF delete or gut, and EGR bypass, can you pass a emission sniff test. I am not asking about the visual, just the sniff.
Thanks,
Barry
http://www.deq.state.va.us/Programs/AirCheckVirginia.aspxWell, my replacement parts are on order. Much thanks to Perry01 for a smoooooth transaction. Question, with a tune and DPF delete or gut, and EGR bypass, can you pass a emission sniff test. I am not asking about the visual, just the sniff.
Thanks,
Barry
I understand that. Wondering what's it's costs for the parts to delete DPF and egr?
I wouldn't be so sure about that. The acceptable emissions limits are not vehicle specific. I think it's very possible, dare I say probable, that you could pass the test. The actual emissions limits may vary from state to state, I don't know.but if you did have to have exhaust sampled, without the cats and DPF installed and working you would fail particulates, hydrocarbons, and NOX. those parts are on the car in the first place because they reduce emissions to specified levels required by law for the model year.
You have a point. (to a point)I wouldn't be so sure about that. The acceptable emissions limits are not vehicle specific. I think it's very possible, dare I say probable, that you could pass the test. The actual emissions limits may vary from state to state, I don't know.
I'm getting mid to upper 40s now. Coming home today 55 miles of highway and a little city driving, I got 46mpg avg by the dash computer.You're welcome. I think we would all like 55-60 mpg. But a more realistic expectation with a delete would be 50 mpg. It's probably wise to hold off until you get a better handle on exactly what kind of testing diesel vehicles are subjected to in your area.
I think what you're looking at with this variance is the regeneration cycle. If you're looking at the trip computer only (that resets after two hours) you will see a lower MPG because more fuel is being used for your regen. The times that you see the higher MPG is a trip where there was no regen. Both these factors into the overall MPG for the tank.I'm getting mid to upper 40s now. Coming home today 55 miles of highway and a little city driving, I got 46mpg avg by the dash computer.
Yesterday I was hovering at 36-38avg mpg.
Go figure....
