gloaming
- Joined
- Nov 3, 2012
- Location
- Port Fishington, Philadelphia
- TDI
- 2010 Golf 6MT CR170 (Sold); 2004 R32 (not a TDI)
The problem with my turn signal started out fairly simple. It would continue to flash after my turn was completed or if I manually cancelled the signal, as if I had hit the lane change signal. Now it has progressed to every time I use the right turn signal it will randomly stop flashing or start flashing to the left. It will continue to do this randomly unless I apply a lot of pressure to it and force it to blink right.
This is pretty dangerous as I make a lot of turns on and off the highway on my way to work (I drive through Philadelphia and through Cherry Hill, NJ so lots of traffic)
I figured I would seek the help of the fine folks on tdiclub before I go to my mechanic. I may try the electronics cleaner fluid.
Thoughts and suggestions? thanks in advance
