Franko6
Vendor , w/Business number
Well, well... Diesel-Dave accuses of trolling, but has been asking loaded questions to me on another thread. Maybe I should call you Igor.
IF a nozzle were to be over-fueling to the extent to make a rod bend(it is true overfueling can wash away lubricant and cause a piston seize) , there would be some very obvious signs. One, the idle balance numbers would be very negative on the injector that is over-fuleing, but more than that, you'd have that white-smoke at startup issue and there would be black smoke on acceleration... Lots of it.
JarHead, you aren't very far from me. It's too bad the car is gone. I can check first and second stages and the flow balance. I'd like to have seen the injectors to lay this FUD to rest.
But that would be the main thing.. Igor shouldn't be coming on a thread and with no more information than what you have told, that Igor would bad-mouth another company's product.
Heck, I HAVE proof of inferior product and I have to watch my step, like some TRUTH might get out. But what YOU are doing, Igor, is banging someone else's drum, trying to downgrade one product and at the same time, trying to put another product in a good light. Only problem is, it's FUD.
Grey Market?? You guys are still on that game? GET OVER IT. You can put handles on them like 'authentic' or Lot numbered, It's the SAME STUFF.
