Wgarner1414
Okay guys I have went through literally hundreds of post today attempting to figure out my issue. I was coming home yesterday and she just died like you turned off the car. No noises or nothing. Car has 167k miles, 5 speed.I have checked codes with VCDS and had a P1561 and a 1562 code both in which are about the quantity adjuster. I replaced the seal on the injector pump about a month ago due to a leak and timed everything at that point. Car has ran fantastic since with no warning of a problem. I have fuel at injectors while turning the car over not pressurized but runs out all 4 injectors. Have check engine and glow plug lights so it’s not the 109 relay. I hear audible click on fuel shut of solenoid as well as 12+ volts on terminal. Timing belt is perfect no missing teeth and tensioned properly. A few bubbles in clear hose but same as been since owner the car since Jan 2013. ASV isn’t stuck did notice some wet oil residue in the hose though. Any advice on what might be my problem? I would like to get it back going as it’s my work/commuter car. Any help would be greatly appreciated!
