Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old February 4th, 2018, 17:54   #1
radmatty
TDI(s): 2005 Passat
Default Natural Gas or Propane Dual-Fuel w/Diesel?
Anybody on the board had any experience with compressed natural gas or propane as a supplemental fuel for performance enhancement or as a dual-fuel scenario?
I saw a couple of YouTube videos created by people seeking to sell equipment to make it possible. They made it look like it was pretty easy to inject a metered stream of natural gas just upstream from the turbo and be running as much as 75% CNG. The benefits seem to be pretty substantial. A cleaner more complete burn of the diesel fuel, increased performance and the ability to use a less costly fuel, in the case of CNG. Of course, carrying any amount of CNG is a pain in the neck due to the high cost of the equipment and the bulky nature of the storage tanks.
Nevertheless, the idea appeals to me. And since I'm contemplating a TDI swap into my Toyota pickup I would have the room and a convenient location to keep a tank or tanks for CNG. With 19 gallons of diesel onboard and 12 gallons equivalent of CNG my truck would have roughly an 1100 mile range.
radmatty is offline   Reply With Quote
Old February 4th, 2018, 21:18   #2
Nevada_TDI
Look up Dr Volks, he is well known for CNG conversions in TDI's.
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Old February 5th, 2018, 08:16   #3
turbobrick240
turbobrick240's Avatar
Running on 75% CNG or LPG would give significantly less performance than straight diesel. Unfortunately, both gasses have pretty poor combustion characteristics for compression ignition engines designed to run on diesel fuel.
Old February 5th, 2018, 11:56   #4
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Negative on running that high %age CNG/LPG, especially with the rudimentary controls to use it in a car and have it properly interact with the existing Diesel fuel injection system and ECU. 10-20% max as a performance enhancer, and I'm sure Bob Mann (CNGVW) will wax poetic about it so I need not say more about it here.
True dual-fuel (gas + pilot Diesel ignition) setups are far more complex and are seen more for truck and stationary engines, but even then are going more towards to mono-fuel natural gas / propane with spark ignition because recent advances have closed the torque and efficiency gaps but at far lower costs and much easier emission control.
Old February 6th, 2018, 06:37   #5
belome
Fuel Economy: 47'ish
Yeah, but your bladder doesn't... stop to pee stop to fuel.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old February 6th, 2018, 18:09   #6
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
Smile
Thank for the kind words TDI Master
Let's see one of my ALH street setup with a computer control system did for added HP and Torque red is with CNG first time on the dyno
This on the Ford truck 70% CNG 30% on one test
the cost of CNG at the time was $1.00 a GAL below is a3 pulls with 2 CNG/D one for max power and one forever day driving
I do not do any more system cost of CNG is too high got a bunch of systems and support stuff I will sell off
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old February 6th, 2018, 21:07   #7
wrenchtech
I was seeing stuff on youtube that made it seem like a thing to look into. It looks like a number of individuals have tried to create businesses selling CNG dual fuel systems, but they seem not to last very long.
Glad to get the straight dope here on TDIclub.
So if anything, CNG or propane are best used as a performance enhancer at low concentration (10 -20%). Any benefits of one of those fuels, one over the other?
wrenchtech is offline   Reply With Quote
Old February 7th, 2018, 10:31   #8
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Propane stores as a liquid, so it has a much higher BTU per volume stored - a tank that fits in the spare tire hole holds more propane than a CNG tank that sits between the rear shock towers.
OTOH, CNG has a higher octane rating and autoignition temperature, making it more resistant to knocking and preignition when fumigating it into the intake of an engine and compressing it 19.5:1.
Old December 22nd, 2019, 22:08   #9
NewTdi
NewTdi's Avatar
Fuel Economy: 58/46/39
Bob Mann, do you have a kit that you are selling for the CNG?
I believe I came across one of your YouTube videos which caught my attention.
03 MK IV Sedan 349k miles - WEEKEND DRIVER WITH A FEW TOO MANY UPGRADES
03 MK IV Wagon 248k miles - DAILY WEEKDAY DRIVER OF CANADIAN ORIGIN
03 MK IV Wagon 500k+ miles - GONE TOO SOON
NewTdi is offline   Reply With Quote
Old February 6th, 2020, 09:51   #10
deckerfl
I have a CNG setup in my Passat TDI (BHW engine) I run about 35% CNG, (my MPG readout shows ~65 MPG vs 40MPG on diesel alone) There is more power but I haven't really tuned it yet for the CNG, so I think overfuelling is limiting my power. Propane is denser, for sure but more expensive. Natural gas at home for me is around $1.00 for 1 GDE, gallon diesel equivalent. but that's ignoring the compressor I have to compress it and repairing that and keeping it running is a whole other expense / time consumer. In fact, in my mind it's the lack of quality home CNG compressors that prevent CNG from being more widely used. I'd do a search and see the cost of CNG at a local CNG pump nearby, and the price of Propane. that maybe the deciding factor.
deckerfl is offline   Reply With Quote
So my friend says my TDi is Diesel is dirty fuel and 3 times the cost of natural gas. Lucihula VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 84 May 3rd, 2012 04:56
Getting Diesel from Natural Gas? PapaBare Fuels & Lubricants 25 April 27th, 2007 20:42
Natural gas converted to diesel fuel Clacketyclak Fuels & Lubricants 1 February 16th, 2005 19:05
Diesel from Natural Gas osidak Fuels & Lubricants 1 August 28th, 2002 06:43
Diesel cleaner than Natural Gas veedub_tdi VW MKIV-A4 TDIs (VE and PD) 14 May 1st, 2002 22:22
Page generated in 0.14819 seconds with 13 queries
[Output: 102.21 Kb. compressed to 87.35 Kb. by saving 14.86 Kb. (14.54%)]
