I think AMC heads are poor. The castings are fair enough, but the components they use are not necessarily the best, but I admit I have never had any experience with an ALH head. The older diesel heads they built had wiped out valve guides after 25k miles, and used very poor quality springs and valves. Our local machine shop can fix them with proper parts, but why have to go through all the trouble on a "new" head?
The waterboxer AMC heads are complete crap, those things would have horrible valve issues in short order, too.
I would be curious to see what a new AMC ALH head is composed of, parts-wise. There are a lot of knock-off bits floating around out there for VAG products largely due to their popularity in China and South America. There are some lifters I have seen that you can tell easily by holding one in your hand is nowhere near as well made as a genuine INA part. I'm sure Frank can share some horror stories of Chinaloy parts as well. The AMC heads are still made in Spain, I think.
Personally, I'd rather have a professionally redone genuine VAG cylinder head, with known quality parts like TRW valves, INA lifters, etc. And if for some reason the head is so bad it cannot be properly put back into service, I'd find a used VAG head to rebuild or just buck up and buy a new Volkswagen head. It'll only be about $300 more for a complete genuine reman head, which is as good as new anyways (and they often ARE actually a new part).
That picture on IDparts website looks like a KS head, actually. AMC heads will have "AMC" in the casting right in the middle, above the spot where the original VAG part number would have been.
