luke.weiser
Ive noticed that my intake manifold is leaking what appears to be oil out of a small hole below the egr valve. What is causing this? looks like a screw hole, but no screw. Anyone experience a similar issue/
No, cleaning it will probably make it leak worse.Yeah, I have the AHU already
So pull it and clean the egr?
Car only has 135k on the clock, dont you guys think thats a little young for an egr cleaning?
Not a good idea.JB weld or quick steel, black electrical tape over CEL!!!!!
Missed the MK3 part. So metal on metal, I guess they can't help but wear, I just figured there had to be an O ring on that shaft some where.There are no o-rings on the shaft, just a metal on metal bushing. EGR valves are mostly made the same way, these are not anything special in that regard.
The only thing that stinks is on the OP's older style TDI engine is that the EGR valve is part of the manifold, unlike the later cars where it is a separate part (and has the anti-shudder valve integral with it).
I actually like the vent idea, that is pretty clever. By now they pretty much all have worn to the point they are weeping some.
it was a joke, see my post above same day #5350957Not a good idea.
They will then have issues with the car running because the vacuum system pulls the diaphragm up and the blocked vent doesn't allow it to return, partially locking it open, returning too much exhaust to the intake smothering it.
I've seen it before and listed why you can't block it in the second post. You can block it if you also block the vacuum port to the Z18 AND block the EGR tubing to the exhaust. The N18 can be faked out electronically, but it takes some time.
