Twinkieflyer
For two years I have lurked here. This is my first post.
I bought my 2002 Jetta 17 months ago. Timing belt had 60k on it, thermostat was leaking so the temp wouldn't get up. Drove it 15k, but got nervous and wanted the car to warm up this winter.
Based on reading here, I bought the idparts hi mileage kit, plus the cam gear and some g12 and thought about doing the job myself. Tools cost at 200 and time made me decide against.
We have an excellent shop that works on myLBZ Duramax, so I questioned them about the job. They said they had the tools, looked a bit different but they have always been very honest, a good independent shop so I went the easy route.
I picked up the car, it was a bit hard to start, and I got a lot of white smoke. The next morning, I had to crank for awhile to start, it cut off, and I had to start it 3 more times to get it to keep running. Once the weekend came I checked the glow plugs, the all read about 1.3 ohms. I kept driving hoping it would get better. It didn't so I took it back. Talked to the guy on the phone, he said the timing showed middle of the graph.
After it is started it restarts fine if started in less than an hour. Power is like before.
I don't want to make this shop mad because they have done so much good work in the past, not sure vw diesels are their prime. So I am faced with either buying the tools, or taking it somewhere else with hands and knees posture.
Car has been at the shop almost 2 weeks. Before, the car started in like one revolution of the crank.
Not sure what the problem is but it sounds like they are a tooth off on the pump.
I just want my car back.
Bill, car less in Blacksburg, VA
