quipstad
Hey everyone,
I've confirmed with my TDI mechanic that my fuel pump is leaking on the high-pressure side. I can tell because the engine cranks for 3-5 seconds every time before starting, and I HAVE to park downhill or the fuel will drain back to the tank and it won't start.They've already tried replacing the cover gasket, which didn't help.
Questions are:
Is there any way to fix the leak without having the thing rebuilt? Mechanic says he only knows of 2 or 3 places in this continent who can rebuild a TDI fuel pump.
Also, is it important to get this fixed ASAP? It's an expensive job and doesn't seem too serious for now but I'm worried about the extra stress on the starter and other things that might be affected by putting it off.
Lastly, I've been dying to get RC3 for a while. Does it matter if I chip a TDI with a leaking pump or should I definitely get the pump fixed first?
Thanks for your help guys.
Questions are:
