My 91 GTI 8 valve to B4 1Z TDI swap
GTiTDi
TDIClub Enthusiast, Macht Schnell! Vendor , w/Busi
3 Spruce st Wareham, gateway to Cape Cod Massachus
'91 GTI CJAA swap,'02 Jetta wagon ALH swap, '03 GTI 1.8T rally car, '03 Sprinter 3500
There's a small chance I'll make it.. If so it will be a whirlwind of a day trip as I have family in from far out of town for the holiday weekend..
Oh man hope you can make it!
I did finally get my coupe mostly shook out.. sure is a lot of fun to go fast AND get 50 mpg :D
That is the best part for sure;) Definitely hard to believe to the uninitiated...Converting many of my car buddies to TDI with high speed trips in the GTI....:cool: One Japanese car enthusiast friend said.."How can you average 90mph and barely use any fuel?!?
myke_w
Cbus, Ohio
03 TDI Wagon
Chris, I hope I can make it too, just depends on the way that weekend plays out...
Hey Kent, I definitely don't want to threadjack so I'll refrain from doing a pic dump.. Hmm.. Maybe I'll start a retroactive build thread...
myke_w
Cbus, Ohio
03 TDI Wagon
Ok Ok.. you made me do it!
pic 1 - In context at least
pic 2 - things that make me go vroom
pic 3 - best one I could dig up in 5 min.. Clearly I need more glamor shots!
GTiTDi
I Love Coupes :D Nice pics Myke! Dustoff this year had four mk2 TDIs in total..I was the only last year! The secret is out they are catching on.....
Frankencar
Dixon, California
1991 GTI +TDI, Lifted 98 NB TDI, Corrado TDI Swap, 15 Golf TDI, a dozen TDI motors etc...
Sounds like the west coast has some catching up to do! ;)
clyde
confluence, Snake/Clearwater
1998 Jetta, 1959 DeSoto with leopard-skin seat covers
Nice looking car, Myke! Was it repainted? Mirror covers that match the body—gooood!
Thanks for giving us a target or goal.
Looks as if you use a Corrado PS reservoir, too…
Kristofk
Aliso Viejo, CA
2004 Golf TDI
You changed your intercooler again?
For the second one, is there enough room to slide in an AC condenser?
How about for the one above?
For the Saab one, it definitely seemed like you can slide one in there, what was the dimensions for that intercooler?
How much HP are you generating?
Im thinking of buying an eBay intercooler kit, but dont know if I need to install special fittings for sensors on the "HOT" side of the intake piping (after the turbo).
GTiTDi
Uh that's not my car.....
With my newer FMIC set up, there is absolutely no room for a condenser. I don't particularly care for air conditioning as I like to cruise with the windows down.
Here is a pic of my bay before I recently changed my air box to one I am experimenting with...
I had to clearance the lock carrier to fit the FMIC...which is made by Spearco. It barely fits, the radiator had to be moved back quite a bit more than with the SAAB intercooler, which for anymore than 20 PSI is not worth the effort as mine failed from constant beating and 28-30 psi..I took the end tanks off of it recently to strip it down for scrap and it does look restrictive. I also ditched the stock plastic boost pipe which had two 90* bends in a row for a less restrictive aluminum pipe which I TIG welded.
GTiTDi
3' stainless side exit with resonator...
^above pic during finalizing adjustment of hangar before welding it...which is why it is offset...now nice and centered
GTiTDi
How's the sound? I bet awesome at about 80 mph!
Deeper, much deeper, and the tone is much smoother...my previous exhaust was less than ideal..one spot in particular was probably causing back pressure...one of those "temporary test purposes only" parts that ended up being semi-permament! ;)
JFettig
Blaine, MN
B5 Passat, 2010 Jetta
I couldn't imagine driving with that exhaust! I have 2 resonators in my Passat, piped straight out the back and it gets to me. I was planning on changing it but now that its not a daily, I'll leave it.
GTiTDi
It isn't nearly as noisy and obnoxious as you would think it may be....May have a lot to do with the fact that it is a wastegate turbo rather than vnt, which sound like jet engines at low speed and idle when vanes are open...:eek:
JFettig
Blaine, MN
Next time you have a VNT TDI in your shop with aftermarket exhaust, pull the vacuum line, thats what mine sounds like at idle :cool:
GTiTDi
I have some customers with loud ALH's, and Pods mk4 Jetta is pretty loud....just took a fellow VW enthusiast for a ride and he thinks my car is actually quieter now
JFettig
Blaine, MN
I still have to go pick up my B5 from my folks' place where I left it to go pick up the JSW
Clutch probably won't hold either :(
GTiTDi
Its a FWD B5, wicked easy clutch to replace! Drive it by my shop on the way to Fest, I will hook you up with a killer deal! ;)
bassman5066
Honey Brook PA
2011 Golf 2 Door TDI (sold back for Dieselgate), 91 Golf 4 Door with 1Z swap
Since were sharing car porn.... :p
Removed huge pic
This is getting installed on the 2011 while I'm in ME and NH with the MK2.
Sent from my Bosch Motronic ECM via VCDS Version 1.9LVE
bassman5066
Honey Brook PA
Sorry bout that. I wrapped it but its going to Diesel dubs in shippensburg pa. Its going in for a timing belt because I didn't wanna do that job so I figured id get the tune done and downpipe installed while its there. 250 for the downpipe install isn't too bad in my book.
GTiTDi
Had a blast with the GTDI at Fest last weekend, the time goes by too fast...next year should be at least a week long! ;):D
Did some more driving on my way back, took a shortcut down the seasonal part of 113 in NH, waterfalls on the road and rivers of water crossing at the low points...was like a paved rally stage at 80 :eek: so fun!
Kind words from Lugnut who drove the GTDI back in July after 40's in a bag
That's GTiTDi's A2, the best all-around performing TDI I've driven. Great handling and comfortable ride manners, brutal amounts of power but velvety-smooth delivery, and biodiesel powered to boot!
Note the silly/stupid smile on the owner? There's a damned good reason for that!
<edit> Oh, that OTHER white car? 87homebuilt's one-off creation that was 12 years in the making? WOW!<end>
and a comment by Tim who took the pic and has driven the GTDI at last Fest...forgot to let him take a update run, oops!
Yea its insanely powerful and smooth riding. I didn't even know I got Chris in the picture until I posted it, haha.
Houpty GT
South Carolina
Corrado TDI, 2000 Golf, 1996 B4 Variant
Let us know how that turns out. Jon seems to think it will upset flow.
You got me thinking that I could build some type of cooling into the long runner SDI intake's EGR system.
