Greetings. I am a semi proud new TDI owner. The reason I say semi proud is because the wagon I purchased has a solid power train under the hood with great maintenance records and a beautifully maintained exterior, but the interior looks like a dozen farm animals were set loose inside it for mating purposes
My questions have to do with swapping interiors. From searching, I know that the front seats from any a4 Jetta will direct swap, but the rear seats have a different base in wagons. To keep things simple, I am looking for swap cars in only wagon format.
What year interiors will direct swap into a 2003 wagon mt with no modification? When I say interior, I mean everything including the door panels and dash plastics. I'm literally going to gut my car, minus the cluster, shifter, and radio because it has an aftermarket installed. I found a 2002 vr6 wagon alx that has beautiful black on tan interior. It's a gas automatic. Will everything fit? I noticed it has electric motion heated seats. Mine are only heated. Will the harness for the movement controls still be present in my wagon?
