sirpuddingfoot
The time has come to make a decision regarding the future of our much-loved Passat.
I was just about to pull the trigger on the delete when oilhammer posted his side-by-side comparison of the BSM Delete vs. Gear-driven BSM. As a result, we are re-thinking the decision and we'd like to poll you and collect your opinions. This is my wife's daily driver and she does value the auto because of the time she spends in traffic. Were it my car, there would be no question.Let's face it, we all expect the torque converter to fail at some point in its service life where a 5 speed rarely has issues.
Option 1:
BSM Delete + 5speed Swap
Pros: Significantly Cheaper. This turns it into essentially the car it should have been from the factory. Reduced rotating mass and complexity (by substituting parts that are relatively failure proof) and no fear of added vibrations since there is no torque converter to worry about.
Cons: The automatic is lost and would have to be explained to a future buyer, etc. The 5spd swap, while being relatively straightforward, is less than ideal for someone who doesn't want to clutch through 2 hours of traffic a day. She also fears a heavy, poor feeling clutch.
Option 2:
BSM Gear Module and Replaced Torque Converter
Pros: Retaining (and returning to) OE drivability. Smoothness and ease of use in extended periods of stop-and-go traffic.
Cons: Significantly more expensive. Retaining complexity. Some chance of failure (though failures seen are attributed to poor installation at this point).
Option 1:
Option 2:
