97 Passat tdi.. ahu, right? Is the 1z head better? If so, why? Does the euro version have the same head? If not, which is it? Basically, which is the best oem head that will bolt to the 1.9 in my 97? If valve sizes and angles are different that's ok. I'll just get the correct pistons and hone the block if necessary.
My goal is to get the best casting to start with and CNC it. I'd prefer something that would bolt right on my 97 Passat, so the engine didn't have to come out.
Which head came on the 130 hp Passats in Europe? Does it have bigger valves?
Thanks,
Chris
Thanks,
Chris
