Zambee500
How firm or snug is the relay supposed to fit into the plug? I know this may sound strange, but it took a little bit of a tug to get the original out. I didn't think to try moving the original back n' forth (left and right, if you will), before pulling it out, so I have no point of reference. I just pulled it straight back, gave it a bit of a tug, and it came right out. But when I put the replacement in, it slid in the 1/4" or so that is the length of the metal prongs on the end, but it seemed to move left & right quite a bit after it was installed. I tried giving it an extra push, but no further movement. Seemed it was going in as far as it was going to, but it still had quite a bit of left-to-right play in it. Took it back out, and it required about the same amount of "tug" effort and came right out, so I put it back in again and it still moved quite a bit left-to-right. Everything seemed lined up correctly though, and the "384" was right-side-up just like the original. I started the car, and the AC came on right away. Is this one of those things where it is either installed correctly and the AC works, or if it's not right the AC doesn't work at all? By that, I mean in the opposite, is it possible to sort of half-a$$ install the relay so the AC works for a bit, but you're possibly risking doing more damage and/or blowing this relay a little while down the road? I didn't feel fully comfortable with it after I was finished, but couldn't figure out what more to do.
And BTW, $120 labor is a friggin' joke on that. I could see how it could take someone literally 2-3 minutes to change it out. As for me, I probably spent 4-6 minutes my first time doing it because I wasn't sure it was all the way in and seated correctly. $120 in labor for that!!???? Between that and the light bulb on the HVAC fan switch, I'm in the wrong line of b'iness.
