+1the turbo will limit you much over 130hp. What injectors do you have? With .216's just bolting them in will yield almost 120hp.
i have a mk3 ahu lump fitted in my t4, is the injector swap simply that or do you need to remap aswell.The turbo will limit you much over 130hp. What injectors do you have? With .216's just bolting them in will yield almost 120hp.
Mitch,i have a mk3 ahu lump fitted in my t4, is the injector swap simply that or do you need to remap aswell.
the ecu isn't the flash type so any map mods become an expensive option.
are you selling the 216 injectors or can you suggest a uk supplier
cheers
mitch
Not my AHH - VNT-15 stock.1Z,AHU and AHH ,all have wastegate.
cool, just want a little more mid range as mainly have caravan on back.Mitch,
You just drop them in for an easy 120hpish. Remap will give you more but not nessasary.
I'm not sure wh has the Injectors in the UK, a few in the US have what is left from the factory.
Ryan
let me know if they turn up.I may have my old 110 nozzles laying around somewhere....
