BrandonH
http://editorial.autos.msn.com/article.aspx?cp-documentid=435706
Althgough my Jetta has been the best car I have owned.
And my 85 TD has been awful , it has only lasted me about 750,000 miles frackin piece of crap . Less than 21 hours & counting to season 4 beginning of BSG Frackin great ............oilhammer said:Heh, my '91 was the bottom-of-the-barrel rating in its day too. As you can guess, it is a horrible car.... what a POS !!! Has only lasted me 17 years and 400k miles. Yeah, I won't ever buy another one. LOL
My headlights are fine also - its the fact there was a recall.tdisedanman said:My 05.5 is running fine. Had the DSG trans serviced just before 40K. Car has original brakes, no dsg trans problems,no oil cooler hose problem, runs great, no headlight issues ( I amied them myself) except they suck even with better bulbs. I'm still glad I have it although I don't like the prices of diesel anywhere from 395 -415 here in So. Florida.
DrewD said:4x,xxx on my 06 TDI and loose exhaust bracket,burned out brake light, and washer fluid hose are only issues I've had. Should I try to lemon law it for the brake light bulb?
Well realistically more Civics were sold so this means nothing.Rod Bearing said:I just did a USED car to car comparison on Edmunds, using the 2005-2006 Honda Civic and the same 2 years of the Jetta. There are far more Hondas on there for sale than Jettas, almost 3 to 1. The prices for similarly equipped cars shows a lot more Civics with lower prices than Jettas.
If I remember correctly, the headlight recall was to install a non tampering part to the headlight aiming adjustment screw.wjdell said:Our 06 Jetta's were doomed with the transmission failures - then the headlight. Possible oil cooler rubbing a hose. Then there were also some brake issues - In a consumer guide that is a the end.
Lets face it - the so called best engine makers in the world put a very poorly designed camshaft in a famous engine, the wealest link. A supplier produced some very bad flywheels and there was improper clip used in the DSG.
Yep, not only did they sell me a car whose low-beams lit up the tree tops (up to spec per dealer ), they also issued a recall that took away my ability to fix the problem following the instructions on this website. To make matters worse, they did the work despite explicit instruction NOT to perform it.farfrumsanity said:If I remember correctly, the headlight recall was to install a non tampering part to the headlight aiming adjustment screw.
They are legally responsible to do what I tell them to do. The contract to do work on my car is between me and them, not between them and VWoA. If they want to do additional work that affects the safety of my car (like dicking around with its lighting system), they need my prior approval.El Dobro said:I'm pretty sure the dealership is legally resposible to perform the recall if the car comes in to them.
The Accord is not a comparable car to the Jetta. The Civic is. Comparing the Jetta to the Accord is foolish.TwoTone said:Well realistically more Civics were sold so this means nothing.
The Accord is a better comparision for price.
I complained about my headlights to the dealer and was told some models had better headlights than others and that the jetta headlights were "not that good". I asked that the aim be checked prior to the recall being done. After the recall I checked my lights on my companies shop door at 25' and was shocked to see that they were all over the place. I laid the required beam pattern out with a laser level and tape, took out the stupid plugs and discarded them and proceeded to aim the lights according to DOT specs. I can now see, I like my lights now and have never had an oncomming vehicle flash their lights at me.farfrumsanity said:If I remember correctly, the headlight recall was to install a non tampering part to the headlight aiming adjustment screw.
