witchcraftz
I have a 2005 BEW TDI Jetta, I have a lead on a 2005 Euro PD 130 TDI engine, includes turbo and all wiring. I have a tiptonric transmission, can this engine be dropped into my Jetta?
Here is a pretty accurate cost breakdown for what a motor swap would cost you (inferring that you are going to pay to have all of the work done, as hinted by the aforementioned post)(also, I've actually done this before, but I'll keep the figures very conservative):My PD100 has a headgasket and turbo gasket leak. A shop will charge $2000 to fix them.
I figured for that price (or a bit more) I might as well look into replacing the whole engine.
Thanks Daniel, that is a really good answer to my question.Here is a pretty accurate cost breakdown for what a motor swap would cost you (inferring that you are going to pay to have all of the work done, as hinted by the aforementioned post)(also, I've actually done this before, but I'll keep the figures very conservative):
- PD130 w/o transmission w/anything you might need for the swap, removed by someone who is trusted enough not to send you a paperweight (it took me 2 complete motors to get one without any issues) $1800
- Shipping and import taxes for said motor w/cylinder head removed (shipping as "auto parts," not a complete motor, as to not run into any bouts with the law for having imported a non-EPA tested foreign motor) $1300 (includes cost for having mechanic carefully remove and separately package cylinder head and all components)
- Labor at qualified shop for removing old motor/trans, installing complete motor, installing trans, reassembling cylinder head, etc. $2500 (never done this, approximate guess for how much time time and work this would be)
- Consumable parts (head bolts, exhaust nuts, flanges, coolant, power steering fluid, oil, oil filter, recharging A/C, etc.) $400
Grand total: $6000
And hopefully there are no unforeseen issues with the motor (like any leaks, excessive shaft play in turbo, etc.)...
I'll bet that hurt pretty brutal last photo!!!If you are putting a PD130/150 into a PD100 car, just swap the bare engine and keep the PD100 EGR, ECU, Intercooler, wiring, everything.
These engine are identical from the outside so it will bolt on directly. Why would you want to use a 2000-2003 ECU in a 2004-2005 car?
If you want to use the european EDC15p ECU, you should swap this in a 2000-2003 ALH car, it fits pretty well.
