You don't need the huge one. Just make sure it's bar and plate and not tube/fin.... ask Jason, lol. Plus the bar and plate ones flow through easier. I have one that is about 5 or 6" tall. 2" deep... and I forget how wide, but pretty much covers the whole center opening on the jetta. I mounted mine below the crash bar, bolted to it. I should make a lower support bracket someday, but have been lazy.
Remember the A/C has the hardest time when stopped. But really this FMIC doesn't limit the amount of airflow that the electric fans do.... It might limit the MAX airflow, but by then you have tons of airflow to cool even a gasser turbo engine
So basically, figure those electric fans are pushing a fraction of the max airflow- so the pressure drop for the cooling airflow is almost nothing. But if you were doing 100 mph, yes the FMIC would be reducing the amount of airflow to the radiators/condensers- because then it would be more of a restriction.
Also, it doesn't really add that much heat to the surrounding area. Even when I was playing with launch control boost, making 12 psi revving at 2500 in N, one side IC pipes were hot to touch. That side of the fmic was hot, and a few inches just warm. The outlet of the fmic and ic pipes there was pretty much ambient... lol
