BarryT82
I contacted the seller and they haven’t replied.
I purchased the PowerStop rotors and pads as a set from Summit Racing on eBay. I ordered them after 9pm on a Friday and they arrived Monday afternoon.My Son and I are gearheads.
He went thru the car with a fresh set of eyes, his overall thoughts were he thought the car presented much better than he expected. He has a 2016 Audi Allroad, with 21k miles on it, so he has a good reference point. He was quite impressed with the way it drove, and said it didn’t feel tired or worn out. He also said it feels quicker off the line than his car. That low down diesel Torque I think.
Have added rear rotors and pads to my list, and might donthe fronts too, as it’s a cheap job. and my son thinks both front and rear rotors were turned as they look worn but have no lip.
Turning rotors hasn't been recommended for at least decades; if it ever was for European imports, I can't remember when. Last time I looked into turning rotors, which had to have been at least twenty years ago, it was more costly to R&R and turn rotors than just putting new ones on. It's more likely they don't have a lip because they haven't been worn down enough to create one.Have added rear rotors and pads to my list, and might donthe fronts too, as it’s a cheap job. and my son thinks both front and rear rotors were turned as they look worn but have no lip.
They're sorta like magically cheap glow plugs that make the 75 cent/gallon price differential between gas and diesel (here anyhow) significantly less painful.What are “Spark Plugs”?
Spent the day at Barrett Jackson yesterday... very cool!
My personal Favorite was a ‘72 Blazer with a Cummins stuffed in it that broke $70k!
Driving back to CA today.
Easily broke 550 miles on this tank, which is still impressive for a 14.5 gallon tank.
We generally find that we run 1/1.5 mpg better on the return journey for some reason.
Might try 38 psi in the tires and see how that feels.
Well, judging by the rest of the car, I doubt they wiped the tailpipe!
Could it be just road dirt or dust?
{code}like this{/code}
Saturday,19,January,2019,16:56:50:55116
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4437.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 193880km-120471mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: Mileage: 193880km-120471miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 36555 002 1048576
VCID: 30391376362E27472E5-8064
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001112050176
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 1471BFE6A276FB672AD-8040
1 Fault Found:
17252 - Transmission Fluid Pressure Adaptation at Limit
P0868 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 2
Mileage: 193675 km
Time Indication: 0
Date: 2013.06.10
Time: 14:19:46
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C49280001880E06E8921C0042B70000
VCID: 7DA7FA42BDFC1A2FF53-8028
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 16
Mileage: 192399 km
Time Indication: 0
Date: 2013.03.19
Time: 22:10:11
Freeze Frame:
Count: 7
Count: 13
Count: 20480
Count: 128
Count: 27136
Count: 5120
Count: 760
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 193075 km
Time Indication: 0
Date: 2013.05.31
Time: 00:00:59
Freeze Frame:
Count: 2
Count: 14
Count: 12800
Count: 16390
Count: 50432
Count: 0
Count: 1284
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001016
Coding: 0000001002
Shop #: WSC 00066 000 00118
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 005983B6CA8E77C79E5-8054
1 Fault Found:
9480465 - Control Circuit for A/C Compressor
B10A9 11 [008] - Short to Ground
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Reset counter: 46
Mileage: 192399 km
Date: 2018.10.29
Time: 22:12:13
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 2F380E1A802F3EC4008800C17000004449000086535D0560648020200040
VCID: 392F2E52E954E60F99B-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 07021 26 0512
Coding: 009795
3 Faults Found:
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 192486 km
Time Indication: 0
Date: 2013.04.01
Time: 06:12:48
Freeze Frame:
Term 15 Off
Voltage: 12.35 V
OFF
OFF
OFF
OFF
OFF
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 14
Reset counter: 46
Mileage: 191891 km
Time Indication: 0
Date: 2013.01.05
Time: 12:55:27
Freeze Frame:
Term 15 On
Voltage: 13.30 V
ON
ON
OFF
OFF
ON
01565 - Luggage Compartment Light (W3)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 32
Mileage: 192562 km
Time Indication: 0
Date: 2013.04.21
Time: 23:09:48
Freeze Frame:
Term 15 Off
Voltage: 12.75 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA14YHE
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDB404AF7F0C83FA7F-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000017GT00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2F336165ZZZY
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4A7A3464ZZZ%
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME7B4A5029ZZZT
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME066E5129ZZZP
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME141E7029ZZZE
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME6C1D7129ZZZS
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KKP000FR
Coding: 188A140000
Shop #: WSC 00066 000 00186
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B5E56E984A4977B49-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0920767
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 303913763AAE27472E5-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 21101101270143
Coding: 352002
VCID: 3A2D315EEC52ED17901-806E
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 192750 km
Time Indication: 0
Date: 2013.05.24
Time: 13:53:50
03272 - Control Module for Audio Interface
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 192750 km
Time Indication: 0
Date: 2013.05.24
Time: 13:53:50
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RFPAA06
Coding: 0000002
VCID: 7EA5FD4EBCFA0137EC9-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC11EDCF29D97201-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661290575
Coding: 010000
VCID: 290FFE1219F4568FE9B-807C
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004022035
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE394DA03A8F41FAB7-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 007 1509
Serial number: 00000006161911
Coding: 000490
1 Fault Found:
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 44
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 70 3301
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 35372262C94C026F7D3-8060
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004017075
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE197C606A6F327A2D-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006108872
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3248952
Coding: 01000400040007
VCID: 6393AC3A3B58CCDFE37-8036
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 248
Mileage: 191862 km
Time Indication: 0
Date: 2012.12.23
Time: 16:49:33
00468 - CD-ROM Drive (R92)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 10
Reset counter: 7
Mileage: 192750 km
Time Indication: 0
Date: 2013.05.25
Time: 11:14:24
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661505826
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BF82A0F6060FFFFF-8072
End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
I’ve been looking at replacing my door reflectors (mine are reflectors if I remember correctly) with these door projectors... I just wasn’t sure how the wiring would work since mine don’t have lights in the first place. https://www.ebay.com/itm/2x-LED-Doo...211207&hash=item26053dd268:g:6~8AAOSwTuJYor6wOn another note...
I noticed I'm missing the passenger door courtesy light(Bottom of the door trim).
Best option to replace that?
