roadking00
Ok so I recently replaced my drivers side door harness, no issues and all seems to be working properly.
A day or so later the front seat heaters stopped working (coincidence I guess) and I found the heated washer nozzle wires damaged and shorting out causing Fuse SC46 (5a) to blow which was apparently part of the A/C Control module and had the heated seats in the mix as well.
Repaired the short and replaced the fuse and it held and my heated seats were back in business. But in the process of trouble shooting I borrowed a 5a fuse from a known good one until I was able to get some additional 5a fuses from the store the next day and of course during that process I blew a borrowed fuse from SC10 (I believe)which is the "Seat occupied sensor control module" I replaced and checked any and all fuses but my AIR BAG light is now on and will not reset via the VCDS so apparently there is something I am missing ??
Years ago I did have the fix for the airbag issue taken care of and all was fine until this snowball situation just happened? So now back to the troubleshooting and was hoping someone can chime in , the existing fault code that continues to return is below.
02511- Control Module for seat occupied recognition (J706)
012 - Electrical Fault in Circuit - MIL ON
