Jake Brake
My flex plate rivets were coming loose and making one heck of a noise!
Getting ready to do my swap over after fixing the tandem pump leak and changing the coolant pipe flange. The tandem pump was leaking really bad. So bad, I can't tell if the oil pan is leaking or in the path of the tandem pump leak. I may pull the pan too, just to rule that out.
My new transaxle is supposed to be in on tuesday
