Hey everybody,
I just purchased an 05 Passat from my brother that needs a new cam and lifters. I'm not new to VW or motor work but I am new to diesels and especially PD's so I could use some advice. Before you tell me to search, I've done tons of research over the past month on the available cam kits and the (possible) up and downsides of each; what I'm noticing is that most of what I can find is either pretty old or non-conclusive.
So my question is: Is the BEW cam significantly more reliable than the BHW cam and worth the possible drop in power? I don't have VCDS right now so I won't be able to adjust torsion values. Also for what it's worth: this car was a one owner, tech-owned car that was maintained with OEM/German made parts and 505.01 spec Lubri-Molly oil at every 10K. The current camshaft and lifters have lasted 257K miles so if it's a toss-up, I'll probably just go with the BHW cam and continue to maintain it the way my brother did.
Edit: this will be my daily driver while I build my race car so cost is a factor. I've already gotten a quote from Frank06 and while I'm sure it's worthwhile, his kits are more than I can spend, as are the Colt cams. As much as I'd love to get the bump in power and probably reliability, I promised my wife this would be an "as little as it takes" car while my Subaru sucks up the rest of the house fund...
Also, anything else I should do while I'm destroying my hands trying to get the crank lock on?
Thanks!
Thanks!
