vwdsmguy
Recently I noticed something like increased snow tire noise in the front. I jacked up the right ft wheel, felt for wheel movment [none], started the engine and spun the wheel up to about 40 , then put in neutral and shut the engine off with the wheel still spinning. Definitely noiser than the left wheel doing the same. This has been going on for about a week. 155K on the bearing. Is it likely the bearing???
If so it looks like a PITA replacment job. I called Salisbury Motors and got a $219 quote for the whole job + tax. [reasonable right]
What to do and how long should it last as is--- Ideas--
