Old February 24th, 2018, 23:23   #1
PHOTOGUY1000
Default Coolant Leak 03 New Beetle TDI
Daughter had coolant light start flashing on her tonight on her way home about 15-20 mins in her 03 new beetle. Light was never solid & engine was not hot when she got home. Car had a bunch of coolant (tank is empty so at least that much) blown over the passenger side of the radiator & passenger side fan. I looked at it for some time didn't see anything obvious. Thermostat housing area is dry... no obvious holes in any hose at least from what I can see topside. I will get under it tomorrow & continue inspection. Was hoping you guys could give me some spots to check? Thanks as always!
Steve
PHOTOGUY1000 is offline   Reply With Quote
Old February 25th, 2018, 18:10   #2
PHOTOGUY1000
it was the lower radiator hose.
'01 Beetle.. massive coolant leak and no start Mr4btTahoe TDI 101 48 March 30th, 2017 15:12
Oil leak. Coolant leak. Injection pump leak. Chris_TDI_98 VW MKIII-A3/B4 TDIs 3 April 23rd, 2016 11:00
coolant loss on 03 TDI can't find leak windyhill VW MKIV-A4 TDIs (VE and PD) 12 November 28th, 2015 08:06
'05 Beetle coolant leak Saskstu TDI 101 4 April 6th, 2015 17:37
Tdi coolant leak jew1028 TDI 101 2 March 14th, 2012 07:41
Page generated in 0.13331 seconds with 13 queries
[Output: 51.80 Kb. compressed to 47.90 Kb. by saving 3.90 Kb. (7.53%)]
