Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Beetle 2012+
VW Beetle 2012+ Discussion area for the 2012+ Beetle TDI (sometimes call the New New Beetle) based on the PQ35 platform.
Old August 11th, 2018, 04:21   #1
showdown 42
Default What to look for in a TDI beetle??
Looking into a TDI beetle convert. I have several in area to choose from. I assume this is the same 2,0 used in the Jettas and passats, correct? I have read they may have belt issues? Any insight would be helpful.
showdown 42 is offline   Reply With Quote
Old August 11th, 2018, 04:27   #2
Lightflyer1
Lightflyer1's Avatar
According to IDParts that is correct. CVCA. I have not heard of any belt issues or had any with mine so far. There isn't much traffic here so don't hold your breath for an answer.
Old August 12th, 2018, 06:18   #3
showdown 42
I've noticed the lack of participation in the Beetle area. Other areas are very actively responded too.
Old August 12th, 2018, 08:32   #4
PB_NB
PB_NB's Avatar
A convertible would be fun. I wonder if the exhaust fumes would be noticeable while sitting in traffic with the top down? Probably very little fumes to speak of with new emissions equipment.
I would get the euro head lights if they can be added as an option.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old August 12th, 2018, 20:29   #5
Lightflyer1
I have had a BMW convertible in the past. It is fun but the convertible tops have very real drawbacks. They wear out fast and are expensive to replace. Leaks, security, noise, etc...
I bought a set of projectors for mine but haven't installed them yet. Along with a RNS315 with nav and backup camera.
Old August 13th, 2018, 07:12   #6
showdown 42
Does anyone have a relatively new beetle convert that has had to replace the top? I would think they would last at least 10yrs under normal weather and garaged.
Old August 13th, 2018, 07:52   #7
Lightflyer1
I am in Texas and the sun cooks them, especially when not garaged.
Old August 13th, 2018, 08:43   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Regarding convertibles in general: if weather permits, and you frequently make use of them, you have a garage to keep them in, and perhaps it is an "extra" car, they are great. Lots of fun!
But I would never, EVER, consider one as my primary vehicle unless perhaps I lived somewhere that allowed me to just keep the top down most of the time.
Regarding Volkswagen convertibles: their tops are among the best in the business. Well fitted, lots of attention to detail, lots of sound deadening, etc. However, this also makes them complicated, heavy, and expensive to repair, service, replace. I doubt anyone yet has had to replace the top on the last NCS based version of the Beetle. But I suspect it won't be any less painful to deal with than the New Beetle (4th gen Golf based) cars, which can often be a heart stopping experience, and most just get sold off as is. Also, some of the power window business can be frightfully expensive and complicated to deal with. There are also some other things on certain models like the rear fold up wings and the rollover protectors that can have issues. The newer versions may or may not have any of those type of problems, too new to know long term.
oilhammer
www.cardocautomotive.com
Old August 13th, 2018, 09:22   #9
Jasper J
Jasper J's Avatar
Smile
I'll come out of "lurk mode" for a moment...
I purchased a 2015 Toffee Brown Convertible "buy-back" this past April, and have put over 10k miles on it so far.
Have previously owned several TDIs and a New Beetle Convertible (a 2006 2.5l non-TDI).
The vert was a ton of fun with no major top problems, so a year after turning in my beloved 2010 Golf, I decided to combine both of my faves into one vehicle.
Found a 2015 CPO buy-back in DC with 6M, Sound and Nav, and drove it back to Utah.
So far it has been great! I have a 60+ mile round trip daily commute, with the top down as much as weather allows.
When topless, there is an occasional whiff of treated diesel exhaust fumes while the engine is warming up, but no more than you'd notice if your windows were rolled down in a non-convertible. Once the engine is warm and in full treatment mode it really isn't noticeable at all.
For VCDS mods, the BCM/ECU seem most related to the MK6 Jetta. I was able to enable the DRL "wink" mode using MK6 Jetta info from the Ross-Tech website.
I just did the 30k oil change-- not too bad overall. The underside Oil filter is a little fussy, but it is in about the same place as the 2.5l New Beetle, so I'm used to it. One Question: Do all TDI Beetles (2013+) have an aluminum skid plate? I was somewhat surprised to see this after all of the plastic ones on previously owned VWs.
I'll try to provide updates, if I run into any issues-- so far the only scare was when the top wouldn't open on command... turns out it was closed during a pop-up thunderstorm and the wet seals between the top and windshield dried and sort-of glued themselves together. After a little gentle persuasion all is good again.
This is my primary vehicle, but it gets garaged when home, and I have a '99 Ford Superduty PSD if things get real bad, but I drove the 06 vert occasionally during Salt Lake winters and it did great in the snow-- the biggest problem was the windows freezing to the top making it difficult to open the doors, oh, and the ground clearance.
I agree with Oilhammer-- VW knows how to make great convertibles (all the way back to the Karmann days). I'll add that the chassis is also really well braced and has a solid feel (the 2015 even more so than the 2006), but there are a lot of little moving parts making that top go up and down-- I almost wish there was a less complicated non-powered version available, but for now I'll cross my fingers and say a little prayer when opening or closing the top, hoping the VW engineering will come through again and provide me with the sun or covering that I desire.
I know this section of the forum is pretty quiet-- most of my TDI related ??s are usually answered in the MK6 Jetta, Passat or MK7 Golf forums, but I'll try to answer if any specific Beetle/Beetle Convertible questions arise.
2015 Toffee Brown Convertible Beetle 6M (Toffifay)
Bought Back: 2010 Candy White Golf 6M
Replaced: 2010 White Gold Jetta Sedan 6M
Replaced: 2003 Reflex Silver Jetta Sedan 01M
Jasper J is offline   Reply With Quote
Old August 13th, 2018, 09:46   #10
oilhammer
oilhammer's Avatar
All the 'verts have a more substantial under tray in front, yes. As do the Eos and TTs. Part of the extra bracing you mention.
Gummi Pfledge (yes, that is the correct spelling) works wonders for keeping all the rubber bits from sticking to things as well as helps keep stuff from creaking in the cold.
oilhammer
Old August 16th, 2018, 03:01   #11
showdown 42
I want to thank Jasper and oilhammer for their posts, It helped me a lot it the decision process. I'm going to get one when I find a late CPO model or maybe order a new one.
Old August 16th, 2018, 08:54   #12
Lightflyer1
You can't order a new tdi convertible. 2015 stop sales were the last new tdi's available.
Old August 17th, 2018, 06:29   #13
showdown 42
I will explore the 2015s CPO if I can find one with low mileage.
Old August 17th, 2018, 06:31   #14
oilhammer
oilhammer's Avatar
And before too long, you will not be able order ANY new ones, as they have already announced the Beetle will be dropped from the lineup due to slow sales. I am sure Dieselgate didn't help, although I don't know how many potential buyers of them would have crossed the car off the list if no diesel option is available. I know there is absolutely nothing on the American Volkswagen dealer showroom that I would want to own new.
oilhammer
Old August 17th, 2018, 10:53   #15
Lightflyer1
IIRC the 2015 Beetle TDI was/is somewhat of a rarity. Very few produced relatively speaking.
BEETLE TURBO S front bumper & install kit beetle tdi sam2007 Private TDI Items for Sale/Wanted 1 August 3rd, 2016 02:44
*parts/project Car* 2000 Beetle Tdi W/99 Beetle Tdi Engine+auto Tranny - $2000 LUI-G TDI Cars for Sale/Wanted 3 August 20th, 2008 21:39
*part Out* 2000 Beetle Tdi Auto &99 Beetle Tdi Engine&98 Jetta Tdi 5-sp LUI-G Private TDI Items for Sale/Wanted 21 March 7th, 2008 00:37
Page generated in 0.19374 seconds with 11 queries
[Output: 126.30 Kb. compressed to 105.06 Kb. by saving 21.24 Kb. (16.82%)]
