Thankful for any help regarding the below..
I have put comments and questions within the text
(sorry about the german code-translations, the only translation I found..)
Passat Variant TDI -2002 VAG-COM Printout.
Instrument
01039 Coolant Temperature Sensor (G2)
01336 Data Bus for Comfort System
- Any ideas regarding these two?
HVAC
01299 -Diagnose-Interface für Datenbus
01341 -Steuergerät im Schalttafeleinsatz am Komfort CAN (J285)
- Where do I start with these? Are they connected to the two above?
ABS
01383 -Alarm durch Sensor für Diebstahlwarnanlage vorn rechts
01385 -Kontrolllampe für Alarmanlage (K95)
- I'm fixing the right front abs-sensor. However the second one, why would the abs-warning light work when it says there's an error?..
CAN
01331 Door Control Module: Driver Side (J386)
01332 Door Control Module: Passenger Side (J387)
01333 Door Control Module: Rear Left (J388)
01334 Door Control Module: Rear Right (J398)
- Seems to be in all doors, where do I start looking on this one? Drivers door or some central module? Tips? I have noticed that the light in the doors and ac goes on and off in 10 minute intervals when used.
Engine
18043 P1635 Data Bus Powertrain missing message f.air condition control
17664 P1256 Engine Coolant Temp Sensor (G62): Open or Short to Plus
- What to do about these?
Climatronic
01272 Central Air Flap Motor (V70)
01274 Air Flow Flap Positioning Motor (V71)
- What would I do about these?.. A clitch within the ac-console?
Instrument
HVAC
ABS
CAN
Engine
Climatronic
